Why Do AI-Ready Workers Still Pass on AI Products?
AI in Practice
AI in Practice
Contributor: Colin Burke
People can feel comfortable using AI but still have little interest in a particular product. Product teams have to determine whether a barrier exists in simply getting started or seeing enough value to choose the tool in the first place.
When Superhuman surveyed knowledge workers, we examined two things: readiness to use AI and interest in an AI-native productivity suite with capabilities like company knowledge search, collaborative documents, real-time writing help, and custom assistants. Those measures did not always move together.
About a quarter of the broader-market sample was interested in the concept but less ready to use AI. Another 14% was ready to use AI but showed little interest in the concept.
Grouping both under “hesitant adopters” obscures what the user experience still needs to prove.
Caution has more than one cause
Within the broader-market sample, the research identified four groups:
  • Engaged and Enabled: 32%. High AI readiness and high interest in the product concept tested.
  • Interested but Inexperienced: 25.6%. Low AI readiness and high interest in the concept.
  • Capable but Cautious: 14%. High AI readiness and low interest in the concept.
  • Disengaged and Doubtful: 28.4%. Low AI readiness and low interest in the concept.
The two middle groups show why “hesitant” is too broad to guide product decisions.
“Interested but Inexperienced” workers need an accessible way to begin, while “Capable but Cautious” workers need a compelling reason to choose the product. Their hesitation reflects different gaps: One group needs confidence, and the other needs product relevance.
Treating both groups as needing more AI education risks solving the wrong problem. Someone who already feels capable with AI may still see no reason to adopt the product.
Familiar tasks make AI easier to evaluate
The segmentation research found that proofreading was the most comfortable AI task among users with lower interest in using AI products. The report separately recommends low-friction onboarding and guidance for “Interested but Inexperienced” workers.
Familiar, easy-to-check tasks can serve both groups for different reasons. They give low-interest users a low-risk way to judge the product and less-experienced users a manageable place to begin.
Proofreading offers a clear before-and-after comparison. People can decide whether the sentence is clearer and still says what they meant, or whether to keep the original if the suggestion falls short.
Summarization creates more to assess: whether the AI captured the main points, preserved important qualifications, and stayed faithful to the source.
Each successful interaction shows people which tasks the system handles reliably, where it needs direction, and when it saves time.
A synthesis across knowledge worker research found that 83% want AI to remember their preferences and improve over time. That should mean fewer repeated corrections. If someone keeps asking for the same change, the product is leaving work with the user that should have been taken off their hands.
Capable users need a stronger reason to adopt
The “Capable but Cautious” group shows that high AI readiness does not guarantee interest in a particular product. These workers may already use other AI tools and see little reason to add another. For this group, the case for adoption depends on whether the product:
  • Improves a recurring task beyond what their current tools offer
  • Uses the context the task requires
  • Keeps its changes visible and controllable
A capable user may see little value in another blank prompt box. The same person may respond differently to AI that can find a relevant customer update while they draft a message, apply established brand guidance inside a document, or prepare work using information already connected to the task.
Broad promises about productivity do little to differentiate one product from another. Specific workflows, visible outcomes, and a clear account of where human review remains necessary help them decide whether the product fits their work.
Control makes review practical
Across the broader market, knowledge workers were most comfortable using AI as a time-saver and creative partner. Comfort declined for precision-sensitive and final-stage tasks such as fact-checking, data analysis, and final polish.
In the research synthesis, 83% said they verify AI output against their own notes or documents, and 71% said they use AI only when they can review or verify the output.
That review step should be built into the product experience. A summary should make its source material easy to find, while an edit should make changes easy to compare. The product should also show what the AI was asked to do, so people can judge whether it stayed within those limits.
Design for the next use
Someone new to AI may need a first task they can check easily. Someone experienced may need the product to solve a problem their current tools leave unresolved. In either case, the next product decision should give that person a reason to return with another task.
Explore the Innovation Hub to see how Superhuman is applying these principles across writing, email, documents, agents, and connected work.
