Cognitive Load Is the Metric No One’s Tracking
Future of Work
Future of Work
Ask a knowledge worker if their tools are working for them, and most will say yes. According to Superhuman’s Human + Technology Index, 86% of workers say their tools help them deliver high-quality work, and 83% say AI makes them feel more accomplished.
So why does it still feel like work is harder than it should be?
The answer lies in a metric almost no one is tracking: cognitive load. It’s the mental effort employees spend before they’ve even started work: deciding which tool to use, where a task belongs, and how much context they have to rebuild every time they move from one tool to another.
Most organizations measure tool adoption, spend, seat counts, login frequency, and tokens consumed. But if you’re not measuring the cost of cognitive load on your employees, you’re missing out on a key metric that actually measures what AI tools are doing to the people using them.
This isn’t a soft, HR-adjacent idea. It’s an operational metric hiding in plain sight, with clear inputs, a measurable spectrum, and a direct line to whether AI helps your team or just adds to their pile. It’s time to start treating it that way.
What cognitive load actually measures
Cognitive load isn’t the measure of how many tools employees use. It measures how much energy goes into making those tools work together: navigating fragmented systems, finding where information lives, choosing between tool options, and figuring out how to move work forward.
Two people using the exact same tech stack can carry completely different loads, depending on how well those tools connect, how much guesswork sits between them, and what they’re trying to accomplish. Most workplaces fall into one of two environments: low or high cognitive load.
The data shows just how far apart those two environments are. In low-cognitive-load environments, where tools connect and work moves without friction, just 15% of workers say that deciding how to do their work takes as much effort as doing it. In high-cognitive-load environments, that number jumps to 95%. The same divide shows up around integration and access to information: 18% versus 96% say their tools don’t work well together, and 16% versus 94% say important information is scattered across too many systems. That’s a lot of people spending their energy on logistics instead of the work itself.
Where cognitive load spikes
Cognitive load isn’t evenly distributed throughout the workday. It concentrates in specific moments, and the data points to exactly which ones.
Workers report losing the most time when coordinating with others (32%) and jumping between tasks (32%), followed by gathering information (26%) and reviewing or revising work (26%).
The friction sits in the seams between work, not in the work itself. Every time work moves between tools, teams, or steps, someone has to stop and figure out where things stand, which is exactly the kind of decision cognitive load is built to measure.
For leaders, this changes where to look. If you want to know where your team’s cognitive load is highest, measure how many times someone pauses, reorients, and chooses a path forward before returning to the task at hand.
When tools add friction, workers create workarounds
When a tool increases someone’s cognitive load, they don’t stop working. But they may stop using company-approved tools and create their own workarounds instead. In fact, 75% of people say they work outside a fully standardized tool stack, relying on a mix of company-provided and personally selected tools to get their work done.
  • 48% say at least half of their tools are personally selected
  • 65% look for AI tools that no one has approved or vetted
  • 61% prefer familiar tools even when better ones are sitting right there, which means the company is paying for—and trying to measure the ROI of—tools that sit unused
When employees avoid company-provided tools, it’s rarely resistance. The top reason is simple: Those tools create more cognitive load. So instead, people reach for what feels simpler, faster, or more connected, even if that means assembling their own tech stack.
Workarounds solve the problem for the individual in the moment, but they create a new one for the organization: fragmented data, underused tools that were already paid for, and governance gaps that widen with every unofficial tool in the mix. The cost of high cognitive load becomes the company’s problem.
Why cognitive load matters now more than ever
Cognitive load has always shaped how work gets done, but AI is what makes it urgent. Every organization is racing to deploy AI into how people already work, and each tool lands in whatever ecosystem already exists. When that environment has low cognitive load, AI tends to deliver on its promise. When it has a high cognitive load, AI inherits the chaos rather than fixing it.
Reducing cognitive load starts with measuring it, and that means asking employees directly. Survey how they actually experience their tools: where they lose time deciding what to use, where context gets lost between one tool and the next, where they’ve built workarounds just to keep moving. How people experience their tools is the clearest window into cognitive load, and cognitive load is the clearest window into what’s really helping them or draining their productivity. Adoption numbers won’t surface any of that. Only the people doing the work can.
From there, the fix isn’t another standalone tool. It’s AI that shows up inside the work itself: connected across the systems people already use, intuitive enough that no one has to relearn how to get something done, and present without requiring anyone to go looking for it. Those are the conditions that actually lower cognitive load. Not one more AI capability to manage, but one less thing to figure out.
Every organization is chasing the same edge in this next phase of work: more output, faster adoption, better AI ROI. The ones that pull ahead won’t get there by adding more features and functionality. They’ll get there by finally clearing the cognitive load that’s been in the way the whole time.
